hm_getinternalid
Returns the internal HyperMesh ID for a solver ID and solver ID pool.
hm_getinternalid id_pool solver_id ?search_type?
HyperMesh Tcl Query Command
This command returns the internal HyperMesh ID for a solver ID and solver ID pool. This command is only applicable to templates and entity types that have ID pools.
id_pool
The pool ID or name. By default, the value is assumed to be the pool ID. This is controlled by the optional search_type argument.
solver_id
The solver ID to query.
search_type
Defines whether id_pool is specified as a pool name or a pool ID. Valid values are -bypoolid and -bypoolname. If not specified, it defaults to -bypoolid.
Examples
To get the internal HM ID of pool ID 1 and solver ID 2:
hm_getinternalid 1 2
or
hm_getinternalid 1 2 -bypoolid
To get the internal HM ID of pool PROP_IDPOOL and solver ID 17:
hm_getinternalid PROP_IDPOOL 17 -bypoolname
   # Handle error
