hm_getmeshfaceparams
Returns all of the relevant automesh settings applied to that surface face.
hm_getmeshfaceparams face_id
HyperMesh Tcl Query Command
This command returns all of the relevant automesh settings applied to a surface face by *set_meshfaceparams. If no automesh settings are applied, no values are returned. The returned values are (in order):
  • shape_type
  • elem_type
  • alg_type
  • elem_size
  • smooth_method
  • smooth_tol
  • size_control
  • skew_control
face_id
The global face ID of the surface face to query.
To get the automesh parameters assigned to face with ID 15:
hm_getmeshfaceparams 15
   # Handle error
Version History
10.0
