hm_historysupporttofile
Writes out to a file the commands that are supported for history.
hm_historysupporttofile filename support_level
HyperMesh Tcl Query Command
- filename
 - The full path and file name of the output file.
 - support_level
 - The type of history support to write the commands for. Valid values are:
To write out the list of unsupported commands to C:\temp\unsupported.txt:
hm_historysupporttofile C:/temp/unsupported.txt 0
   # Handle error
}Version History
14.0
