hm_getgeomtopologytype
Returns the topology type of a geometric entity.
hm_getgeomtopologytype entity_type id
HyperMesh Tcl Query Command
Returns the topology type of a geometric entity. Return types include:
  • points - none, vertex, fixed
  • lines - none, free, shared, nonmanifold, suppressed
  • surfs - free, bounding, partition, fin
  • solids - 1dmappable, 3dmappable, unmappable, ignoredmappable
entity_type
The type of entity to query. Valid values are points, lines, surfs and solids.
id
The ID of the entity to query.
To query the topology of surface 100:
hm_getgeomtopologytype surfs 100
   # Handle error
Version History
2017.1
