hm_comparereadfile
Reads comparison data from a file into the comparison database.
hm_comparereadfile filename overwrite
HyperMesh Tcl Query Command
Reads comparison data (transformations, match types, match entities, etc...) from a file into the comparison database. This must be preceded by a call to hm_compareinit.
This is useful for large comparisons that take a lot of time to generate. The data can be saved to a file and reloaded in a new session to save time.
filename
The full name and path of the file to read the data from.
overwrite
0 - Do not overwrite existing comparison results
1 - Overwrite existing comparison results
To write the comparison data file to C:/temp/my_compare.txt for the same side comparison of surfs 1-20 and 101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiessameside surfs 1 surfs 2 0.1 2 0
hm_comparewritefile C:/temp/my_compare.txt
hm_compareend
To read the comparison data file from C:/temp/my_compare.txt and review the distances:
hm_compareinit
hm_comparereadfile C:/temp/my_compare.txt 1
hm_comparefinddistances 1.0 1
hm_comparesetreview 2
hm_compareend
   # Handle error
Version History
12.0
