hm_ishistorysupported
Returns the history support level for the specified command.
hm_ishistorysupported command
HyperMesh Tcl Query Command
Returns the history support level for the specified command. The return values are as follows:
  • -1 - Command does not modify the database and therefore does not affect history
  • 0 - Command is not supported for history
  • 1 - Command is supported for history
command
The name of the HyperMesh Tcl Modify Command command to query.
To query the support level of *displaynone:
hm_ishistorysupported *displaynone
   # Handle error
Version History
14.0
