hm_getdistancefromnearestline
Gets the distance of the given point from the nearest line with IDs specified as arguments.
hm_getdistancefromnearestline point_xyz line_id_list
HyperMesh Tcl Query Command
point_xyz
The list of x, y, z coordinates of the point.
line_id_list
List of line IDs.
Examples
The function returns a list consisting of two values. The first value is the distance to the closest line. The second value is ID of the closest line.
To get closest to the point with coordinates (10, 20, 30) point on the line with ID 13:
hm_getdistancefromnearestline [list 10 20 30] 13
To get closest line from the set with IDs 13 14 15:
hm_getdistancefromnearestline [list 10 20 30] [list 13 14 15]
To get closest to the node with ID 2 point on the line with ID 13:
hm_getdistancefromnearestline [hm_getvalue nodes id=2 dataname=coordinates] 13
None.
