hm_proximitymarkcomponentallelementpairs
Marks the element pairs for a specific component pair.
hm_proximitymarkcomponentallelementpairs component_pair_index mark_id1 mark_id2
HyperMesh Tcl Query Command
This must be preceded by a call to hm_proximityinit and followed by a call to hm_proximityend.
The index of the component pair. This starts from 0 and must be less that the value returned by hm_proximitygetcomponentpaircount.
mark_id1
The output mark on which the elements for the first component are placed.
mark_id2
The output mark on which the elements for the second component are placed.
To calculate the proximity between all comps using a max distance of 2.5 and to query the component pairs:
*createmark comps 1 all
hm_proximityinit comps 1 2.5
set comp_pair_count [hm_proximitygetcomponentpaircount]
for {set i 0} {$i < $comp_pair_count} {incr i} {
    set comp_pair [hm_proximitygetcomponentpair $i]
    puts "Component pair $i: $comp_pair"
    set elem_pair_count [hm_proximitygetcomponentelementpaircount $i]
    for {set j 0} {$j < $elem_pair_count} {incr j} {
        set elem_pair [hm_proximitygetcomponentpair $i $j]
        puts "    Element pair $j: $elem_pair"
hm_proximityend
   # Handle error
Version History
14.0
