hm_ce_xmlstringget
Returns connector information in XML format.
hm_ce_xmlstringget id
HyperMesh Tcl Query Command
id
The ID of the connector to query.
To get the XML formatted information for connector 100:
hm_ce_xmlstringget 100
   # Handle error
Version History
11.0.101
