hm_getboundingbox_predefined
Returns the bounding box for a predefined box trim cut.
hm_getboundingbox_predefined mark_id predefinedcut limit
HyperMesh Tcl Query Command
This command returns the six values defining the bounding box for a mark of elements for a predefined box trim cut.
x_min y_min z_min x_max y_max z_max
The box values are determined depending on the following options.
mark_id
The ID of the mark containing the elements. Valid values are 1 and 2.
predefined_cut
The name of a predefined cut. Valid values are:
  • front
  • rear
  • right
  • left
  • frontright
  • frontleft
  • rearright
  • rearleft
limit
The x value of the box for predefined cuts front, rear, frontright, frontleft, rearright and rearleft.
To get the bounding box for the displayed elements using a front cut with a limit of 0.1:
*createmark elems 1 displayed
hm_getboundingbox_predefined 1 "front" 0.1
   # Handle error
Version History
11.0.130
