hm_info
Query general information about HyperMesh options and paths.
hm_info option|-appinfo info_option ?value?
HyperMesh Tcl Query Command
This command returns general information about HyperMesh options and paths.
- -appinfo info_option
 - Valid info_option values are:
- ALTAIR_HOME: Current installation base directory.
 - ARCHITECTURE: Current system architecture.
 - COPYRIGHT: The HyperWorks copyright text.
 - CURRENTWORKINGDIR: Current working directory.
 - DISPLAYVERSION: The full application version number (for example, 10.0b40).
 - EXECUTABLEDIR: Full directory path of the application’s executable. Same as HMBIN_DIR.
 - EXECUTABLEPATH: Full directory path and file name of the application’s executable.
 - FILEVERSION: The exact version string created by the template variable hmversion during export.
 - HMBIN_DIR: Full directory path of the application’s executable. Same as EXECUTABLE_DIR.
 - LICENSE_FEATURE: Application’s license feature.
 - LICENSEVERSION: Application’s license version.
 - NAME: Get the applications name.
 - PATCH_NUMBER: The base application patch number (for example, 101, 102).
 - SPECIFIEDPATH type: Full path name of the specified type. Valid
                type values are:
- altair_lic.dat
 - EXTERNALFUNCS_DIR
 - EXTERNALREADERS_DIR
 - EXTERNALWRITERS_DIR
 - hm
 - hm_dll_readers
 - hm_feinput_readers
 - hm_mac
 - hm_module
 - hm_scripts_dir
 - hm_user_profiles
 - hm40_translator
 - hw_help_dir
 - hw_readers
 - hw_tcl_common
 - hyperbeam
 - hypercrash
 - mv_solver_writers
 - nastran_to_abaqus_converter
 - radioss_launchdir
 - standard_statistics_template
 - tcl_lib
 - TEMPLATES_DIR
 - tk_lib
 - TRANSLATORS_DIR
 - wish
- SUPPORTEMAIL: The HyperMesh tech support email address.
 - TITLE: Title of the application.
 - VERSION: The base application version number (for example, 10.0).
 - XDISPLAYNAME: The name of the current X display.
 - analysisfileset
 - Returns 1 if the global results file is set; 0 otherwise. Identical to resultfileset.
 - cardprev_displayed
 - Returns 1 if the card previewer is displayed; 0 otherwise.
 - commandfilename
 - Full path and file name of the command file from the "files" panel. This option cannot be used in HyperMesh Batch Mode.
 - currentcollector type
 - Returns the current collector ID of the specified type or 0 for no current collector. Valid type values are beamsectcol, comp, loadcol, module, multibody, systcol, and vectorcol.
 - currentcomponent
 - Returns the current component collector ID.
 - currentinclude
 - Returns the current include file shortname.
 - currentfile
 - Full path and file name of the current HyperMesh database. Identical to hmfilename.
 - database_empty
 - Returns 1 if the database is empty; 0 otherwise.
 - database_modified
 - Returns 1 if the database has been modified since the last save operation; 0 otherwise.
 - elems_cleanup
 - Returns 1 if the user is in the quality index panel; 0 otherwise.
 - emptylist entity_type
 - Returns the list of empty entities of the given entity_type. Valid entity_type values are: assems and comps
 - entity_types_allowing_undefined
 - Returns the entity types that are supported as allowing undefined entities.
 - executing_command
 - Returns 1 if HyperMesh is currently in the process of executing a command; 0 otherwise.
 - exportfilename
 - Full path and file name of the export file from the "files" panel. This option cannot be used in HyperMesh Batch Mode.
 - exporttemplate
 - Full path and file name of the export template from the "files" panel. This option cannot be used in HyperMesh Batch Mode.
 - functionlock
 - Returns 1 if HyperMesh is currently in the function lock mode due to being in a secondary menu like automeshing; 0 otherwise.
 - geomstyle
 - Returns the geometry color mode value set by *settopologydisplaytype.
 - hmfilename
 - Full path and file name of the current HyperMesh database. Identical to currentfile.
 - hyperstudy_running
 - Returns 1 if HyperStudy is currently in the process of running after being launched from HyperMesh; 0 otherwise.
 - importfilename
 - Full path and file name of the import file from the "files" panel. This option cannot be used in HyperMesh Batch Mode.
 - importtranslator
 - Full path and file name of the import translator from the "files" panel. This option cannot be used in HyperMesh Batch Mode.
 - istemplateloaded
 - Returns 1 if a template file is loaded; 0 otherwise.
 - lastselectedentity entity_type
 - Returns the ID of the entity of the specified entity_type that has been selected using *createentitypanel. This command must be called immediately after the *createentitypanel command. If there are any errors or no entity has been selected, the value returned will be 0.
 - macrofilename
 - Full path and file name of the macro file. This option cannot be used in HyperMesh Batch Mode.
 - macromenupage
 - Returns the page number that the Utility tab is currently set to.
 - plottingdisplay
 - Returns 1 if HyperMesh is currently involved in a plotting process that makes use of the alternative display list (fill plot for hidden lines, contour, etc…); 0 otherwise.
 - prompting
 - Returns 1 if HyperMesh is currently prompting the user for an immediate response using an Overlay or a Popup; 0 otherwise.
 - pushtofront entity_type
 - Returns the value set by *pushtofront for the specified entity type. Currently only supported for tags.
 - readingfile
 - Returns 1 if HyperMesh is currently in the process of reading an HM file; 0 otherwise.
 - resultfilename
 - Full path and file name of the result file.
 - resultfileset
 - Returns 1 if the global results file is set; 0 otherwise. Identical to analysisfileset.
 - reviewmode
 - Returns the review mode value set by *setreviewmode.
 - somethingtoreject
 - Returns 1 if the reject operation will have any effect if executed now; 0 otherwise.
 - templatecodename
 - The name reported from the current template’s *codename() command.
 - templatefilename
 - Full path and file name of the current tempate file.
 - templateid
 - The ID reported from the current template’s *codename() command.
 - templatetype
 - Current template type. This is one of the predefined template types, currently one of the following: nastran, abaqus, marc, autodv, hyperopt, pamcrash, patran, ansys, lsdyna, dytran, simex, phlex, pdm, mainfile, or none. Some template type names are not reported. For example, a madymo template will be reported as an lsdyna template.
 - tempnam
 - Full path and file name of a temporary file. The value returned from each call is unique.
 - unusedlist entity_type
 - Returns the list of unused entities of the given entity_type. The list will contain names for named entity types and IDs for all other types. Valid entity_type values are curves, contactsurfs, ellipsoids. mats, mbjoints, props, and systs.
 - writeviewcommands
 - Returns the value set by hm_writeviewcommands or the -nowriteviewcommands start-up option.
Examples
set trans_dir [hm_info -appinfo ALTAIR_HOME]set trans_dir [hm_info -appinfo SPECIFIEDPATH TRANSLATORS_DIR]set cur_veccol [hm_info currentcollector vectorcol]Errors
   # Handle error
}Version History
2020 - Added new -appinfo option FILEVERSION.
