hm_entity_setvector
Set the vector ID for the weld element.
hm_entity_setvector entityType entityID vectorID
HyperMesh Tcl Query Command
- entityType
 - The type of entity to associate with the property (currently, only ELEMS are supported).
 - entityID
 - The ID of the entity.
 - vectorID
 - The ID of the vector.
To set vector of ID 1 to an element of ID 5:
set ent_id 5;
set vec_id 1;
hm_entity_setvector ELEMENTS $ent_id $vec_id;
      This function is currently supported for spring and gap element configuration only.
None.
