hm_getcollectorname
Returns the name of a collector.
hm_getcollectorname entity_type id
HyperMesh Tcl Query Command
entity_type
The type of entity to query. Currently supported for all collector entity types.
id
The ID of the collector.
To get the name of the component with ID 100:
hm_getcollectorname comps 100
   # Handle error
