hm_fe_getWvsTfile
Returns the width vs thickness file for seam welds.
hm_fe_getWvsTfile
HyperMesh Tcl Query Command
None.
Examples
To query the file:
set wtfile [hm_fe_getWvsTfile]
   # Handle error
Version History
2021
