hm_wadlinessethood
Sets the entities for the hood used to create the reference line.
hm_wadlinessethood entity_type mark_id
HyperMesh Tcl Query Command
This API must be used after initializing the wadlines analysis using hm_wadlinesinit.
entity_type
The type of entities being set for the hood. Valid values are comps, surfs and elems.
mark_id
The ID of the mark containing the hood entities. Valid values are 1 and 2.
Examples
To set the hood entities to comps 102 and 103:
*createmark comps 1 102 103
hm_wadlinessethood comps 1
   # Handle error
Version History
2020
