hm_findclosestpointonsurface
For a given point on a surface, returns the closest other point on that same surface.
hm_findclosestpointonsurface x y z surf_id
HyperMesh Tcl Query Command
For a given point on a surface, returns the closest other point on that same surface:
xs ys zs dist
where xs, ys and zs are the coordinates of the point on the surface closest to input point, and dist is the distance between the original and projected points.
x y z
The coordinates of the known point.
surf_id
ID of the surface.
To find the point closest to a point with coordinates (2676, -737, 605) and located on surface 7:
hm_findclosestpointonsurface 2676 -737 605 7
2.6777E+003 -7.3989E+002 6.0481E+002 3.3889E+000
   # Handle error
