hm_ce_fedata
Returns the weld config or the tolerance set to realize a connector.
hm_ce_fedata ce_id function
HyperMesh Tcl Query Command
- ce_id
 - The ID of the connector.
 - function
 - One of three possible strings:
To get the current weld config set for connector with ID 1:
set ce_id 1;
set config [ hm_ce_fedata $ce_id "configval" ];
      Currently only configval and tolerance are supported for the connector.
None.
