hm_attributenamefromid
Returns an attribute name from the attribute ID for the current template.
hm_attributenamefromid attribute_id
HyperMesh Tcl Query Command
Returns an attribute name from the attribute ID for the current template. If the attribute does not exist in the current template, an error is returned.
attribute_id
The ID of the attribute to query.
To get the attribute name of the attribute ID 100:
hm_attributenamefromid 100
   # Handle error
Version History
10-SA1-110
