hm_jobs_addServer
Add a new server.
hm_jobs_addServer name host port
HyperMesh Tcl Query Command
This command is used to add a server. The same information will be saved for later use in the server config file.
name
The name of the server to be added.
host
The host/IP of the server. Note that the "local" server is always available by default.
port
The port number on which the server will communicate.
To add a server named HWUL with IP 122.0.0.1 and port number 17084:
hm_jobs_addServer HWUL 122.0.0.1 17084
   # Handle error
Version History
14.0.130
