hm_comparewritepairedcomps
Writes a list of pairs of source and target components to an output file.
hm_comparewritepairedcomps filename match_type
HyperMesh Tcl Query Command
This helps extract relevant compare component data from hm_comparewriteresults. This must be preceded by a call to a relevant hm_compareentities* command.
filename
The full name and path of the file to write the results to.
match_type
The type of match to query for the area. Valid values are:
0 - Unmatched
1 - Topological
2 - Intersected
3 - Overlapped
4 - Matched
Examples
Compare assembly 1 to assembly 2 and write the paired results to C:/temp/paired_compare.txt:
*createmark elems 1 "by assems" 1
*createmark elems 2 "by assems" 2
hm_compareinit
hm_comparesetflags 1
hm_compareentitiessameside elems 1 elems 2 1.0 2 0
hm_comparewritepairedcomps C:/test/paired_compare.txt 4
hm_compareend
   # Handle error
Version History
2020
