hm_getmark
Returns the entity IDs of the passed entity type on the specified mark.
hm_getmark entity_type mark_id ?panel_sensitive? ?model_name?
HyperMesh Tcl Query Command
- entity_type
 - The type of entity to query.
 - mark_id
 - The ID of the mark containing the entities. Valid values are 1 and 2.
 - panel_sensitive
 - Can be used when multiple panel levels have been pushed, either using the shortcut function keys, or the hm_pushpanel command. This option determines whether to use the current panel or the previous panel for the operation. This option is relevant only when the mark has been created from a panel entity selector under the above conditions. Valid options are:
 - model_name
 - The optional model to get the mark for. If not specified, the current model is used.
Examples
hm_getmark comps 1hm_getmark comps 1 0 model-2hm_getmark loads 1 1hm_getmark loads 1 0Errors
   # Handle error
}Version History
2020 - Added new option model_name.
