hm_getcriteria
Query the values of global mesh quality criteria.
hm_getcriteria criteria
HyperMesh Tcl Query Command
criteria
The name of the criteria to query. Valid values can be found in *criteria_update.
There are also a few special criteria names:
global_solver
The global calculation method to be used for all quality parameters.
legend_colors
The legend colors for all thresholds.
If no criteria value is given, all criteria values are returned.
Examples
To get the 2D min size:
hm_getcriteria min_size_2d
To get the 3D aspect ratio:
hm_getcriteria aspect_ratio_3d
To get all values:
hm_getcriteria
   # Handle error
Version History
2021
