hm_ce_getlinkinfo
Returns link info for a connector including entity type, IDs/names, locator rule and XYZs.
hm_ce_getlinkinfo id index
HyperMesh Tcl Query Command
id
The ID of the connector to query.
index
The index of the link on the connector.
To get link information for connector ID 1 for all links:
set ce_id 1
set num_ents [hm_ce_numlinkentities $ce_id]
for {set count 0} {$count <= $num_ents} {incr count} {
foreach {type info state rule} [hm_ce_getlinkinfo $ce_id $count] {
lappend linkArray($type) $info
   # Handle error
Version History
10-SA1-120
