hm_getelementcheckmethod
Returns the method (solver) currently being used for calculating specific element quality checks.
hm_getelementcheckmethod check_name ?method_mode?
HyperMesh Tcl Query Command
This command returns the ID of the method (solver) used to calculate the specified element quality check. For element quality check parameters, their meanings and allowable values, see the *elementchecksettings command.
check_name
Specifies the element quality check parameter to query. Valid values are:
  • angle
  • aspect_2d
  • aspect_3d
  • cell_squish_2d
  • cell_squish_3d
  • chord_dev
  • equi_skew_2d
  • equi_skew_3d
  • jacobian_2d
  • jacobian_3d
  • min_len_2d
  • min_len_3d
  • ortho_3d
  • size_ratio_3d
  • skew_2d
  • skew_3d
  • solver
  • taper
  • tetra_collapse
  • time_step
  • warpage
get_method_mode
An optional parameter specifying the mode of retrieving of the returned method. Valid values are:
0 - Returns the method stored globally, regardless of global or individual solver mode.
1 - Return the method specified by the global solver (if an individual solver mode is not being used).
2 - Return the actual method used in calculations. This is the default value.
To retrieve the method currently being used for calculation of the aspect ratio for 2D elements:
set aspect2dmethod [ hm_getelementcheckmethod  aspect_2d]
To retrieve the method currently being used for calculation of the Jacobian for 2D elements:
set jacobian_method [ hm_getelementcheckmethod  jacobian_2d]
   # Handle error
Version History
10-SA1-110
2019 - Added new check_name values ortho_3d and size_ratio_3d.
2020 - Value 5 (Nastran) is now supported for return for check_name aspect_2d.
