hm_gethmfileversion
Returns the binary file version string for a specified HyperMesh database.
hm_gethmfileversion filename
HyperMesh Tcl Query Command
Returns the binary file version string for a specified HyperMesh database. The string is comprised of 2 parts, major-minor, where:
  • major is the major file version. It is itself comprised of two parts, release.binary.
  • minor is the minor file version.
    For example: 13.02-110
filename
The full path and filename of the database file. Paths with spaces must be enclosed in quotes.
To get the file version for C:\temp\test.hm:
hm_gethmfileversion  C:/temp/test.hm
   # Handle error
Version History
13.0.110
