hm_diffencodings
Calculates the distance between two lists of encoded strings representing shapes of geometries.
hm_diffencodings encodings1 encodings2 ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Query Command
Calculates the distance between two encoded lists representing shapes of geometries. The geometries can be CAD, FE or a mixture. Typically this is the Euclidean distance normalized by the number of entries in the encoding. The encodings are generated by hm_encodeshape.
encodings1
The first list of encodings generated by hm_encodeshape.
encodings2
The second list of encodings generated by hm_encodeshape.
encoding_algorithm
The optional encoding algorithm to use. Valid values are:
0 - Spherical harmonics (default)
sphhar_bandwidth
Optional, valid for encoding_algorithm 0, default 16.
sphhar_fallof
Optional, valid for encoding_algorithm 0, default 2.828427.
sphhar_radii
Optional, valid for encoding_algorithm 0, default 32.
sphhar_resolution
Optional, valid for encoding_algorithm 0, default 64.
Examples
To calculate and diff the encodings from all surfaces against all elements:
*createmark surfs 1 all
set x [hm_encodeshape surfs 1]
*createmark elems 1 all
set y [hm_encodeshape elems 1]
hm_diffencodings $x $y
   # Handle error
Version History
2020.1
