hm_wadlinesgetreferenceline
Returns coordinate data defining WAD reference lines.
hm_wadlinesgetreferenceline line_location ?offset? ?method?
HyperMesh Tcl Query Command
- line_location
 - The location of the line to query (0=front, 1=rear, 2=left, 3=right, 4=upper bumper, 5=lower bumper, 6=left corner, 7=right corner). The data will be returned as a list of doubles. Every three doubles are the X, Y, and Z coordinates of a point along the line. The lines all run from front to back and from left to right.
 - offset (optional)
 - Argument that defines an offset to apply when querying the rear, left and right reference lines. A positive value offsets the line toward the center of the bonnet by the specified value. Negative values are supported, but should not be necessary.
 - method
 - The method to use for measuring the offset distance.
To setup and extract WAD lines data:
hm_wadlinesinit
hm_wadlinessetparameters 45.0 50.0 100.0 100.0 50.0 20.0 25.0 60.0
hm_wadlinessetaxes 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.0
*createmark comps 1 "bonnet" "bumper" "fenderL" "fenderR"
*createmark comps 2 "windshield" "a-pillars"
hm_wadlinessetentities comps 1 comps 2
*createmark elems 1 "by collector" wipers
hm_wadlinessetwipers elems 1 0 1
hm_wadlinesgetreferenceline 0
hm_wadlinesgetreferenceline 1
hm_wadlinesgetreferenceline 2
hm_wadlinesgetreferenceline 3
hm_wadlinesgetreferenceline 4
hm_wadlinesgetreferenceline 5
hm_wadlinesgetreferenceline 6
hm_wadlinesgetreferenceline 7
hm_wadlinesgetwadline 1000.0
hm_wadlinesgetwadline 1500.0
hm_wadlinesgetwadline 1700.0
hm_wadlinesgetwadline 2100.0
hm_wadlinesgetgridpoints 1000.0 1500.0 1700.0 2100.0 50.0
hm_wadlinesend
   # Handle error
}Version History
12.0.110
