hm_getshelloverlapinfo
Returns information regarding proximity overlap between a selection of components or elements.
hm_getshelloverlapinfo source_entity_type source_mark_id target_entity_type target_mark_id maximumproximitydistance
HyperMesh Tcl Query Command
Returns information regarding proximity overlap between a selection of components or elements. The command returns the proximity overlap area, the overlap volume, the maximum and minimum proximity distance, the coordinates of the overlapping bounding box corners in the global system, the origin of the bounding box, and its x, y, z vectors from the origin in the following format:
<proximity_area> <proximity_volume> <max_proximity_distance> <min_proximity_distance> (Bounding Box info){{MinPointX MinPointY MinPointZ} {MaxPointX MaxPointY MaxPointZ}} (PCA Box info){{OriginX OriginY OriginZ} {XVectorX XVectorY XVectorZ} {YVectorX YVectorY YVectorZ} {ZVectorX ZVectorY ZVectorZ}}
source_entity_type
The type of source entity. Currently supported for components and elements.
source_mark_id
The ID of the mark containing the source entities. Valid values are 1 and 2.
target_entity_type
The type of target entity. Currently supported for components and elements.
target_mark_id
The ID of the mark containing the target entities. Valid values are 1 and 2.
maxproximitydistance
Maximum proximity distance below which the overlap is calculated.
Examples
To get overlap information between component 7100314 and component 7100361 for a proximity distance of 5.0:
*createmark comps 1 7100314
*createmark comps 2 7100361
hm_getshelloverlapinfo comps 1 comps 2 5.0
   # Handle error
Version History
2021.2
