hm_exportplyorientation
Writes the fiber orientation vector for each element in a ply to a text file.
hm_exportplyorientation mark_id filename
HyperMesh Tcl Query Command
- mark_id
 - The ID of the mark containing the plies to write. Valid values are 1 and 2.
 - filename
 - The full path and filename of the text file.
Examples
To write the fiber orientation vector for elements in all plies:
*createmark 1 plys all
hm_exportplyorientation  1 "C:/temp/drape.txt"
   # Handle error
}Version History
2019
