hm_ispointinsidesolidelem
Checks whether a point is inside the volume of a solid element.
hm_ispointinsidesolidelem x y z elem_id
HyperMesh Tcl Query Command
This command returns 1 if the point is found to be inside the solid element and 0 otherwise.
- x , y , z
 - The (x,y,z) coordinates of the point.
 - elem_id
 - The ID of the solid element.
To check whether the point with coordinates 10, 20, 30 is inside the solid element with ID 1:
hm_ispointinsidesolid 10 20 30 1
   # Handle error
}Version History
12.0.110
