hm_comparegettransformationmatrix
Returns the 4x4 transformation matrix for a specific transformation.
hm_comparegettransformationmatrix transformation_index
HyperMesh Tcl Query Command
Returns the 4x4 transformation matrix (16 values) for a specific transformation. This must be preceded by a call to a relevant hm_compareentities* command.
The index of the transformation to query, starting with 0. The number of transformations can be found using hm_comparegettransformationcount.
To find the transformation matrix for transformation 0 for the recursive comparison of surfs 1-20 and 101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiesrecursive surfs 1 surfs 2 0.1 2 0
set matrix [hm_comparegettransformationmatrix 0]
hm_compareend
   # Handle error
Version History
12.0
