hm_getsolver
Returns the name or ID of the solver as provided by the template *codename() command.
hm_getsolver ?value?
HyperMesh Tcl Query Command
Returns the name or ID of the solver as provided by the template *codename() command. If no name is provided, or no template is loaded, "none" is returned.
- value
 - An optional argument that specifies the type of value to return.
Examples
To get the name of the current solver:
set solver_name [hm_getsolver]
      or
set solver_name [hm_getsolver name]
set solver_id [hm_getsolver id]
None.
