hm_getmodelcheckfailedcount
Returns the number of entities failing a given model checker check.
hm_getmodelcheckfailedcount check_name
HyperMesh Tcl Query Command
check_name
The name of the check, as given in the model checker config file.
To get the number of entities failing the "Number of defined materials" check:
hm_getmodelcheckfailedcount "Number of defined materials"
   # Handle error
Version History
2017.1
