*systemcreate3nodes
Creates a rectangular coordinate system.
*systemcreate3nodes type origin axisname axispt planename planept
HyperMesh Tcl Modify Command
- type
 - The type of system being created.
 - origin
 - The ID of a node which defines the origin.
 - axisname
 - A string which identifies the axis being defined with the next parameter (x, y, or z).
 - axispt
 - The ID of a node which defines a point on the axis defined by axisname.
 - planename
 - A string which identifies the plane being defined with the next parameter (xy, xz, or yz).
 - planept
 - The ID of a node which defines a point on the plane defined by planename.
*systemcreate3nodes(1,1,x,2,xy,3)Errors
None.
