*createplane
Defines a plane for use in a subsequent command.
*createplane plane id normal x normal y normal z base x base y base z
HyperMesh Tcl Modify Command
- plane id
 - The ID of the plane being defined (1 or 2).
 - normal x
 - The x component of the normal of the plane.
 - normal y
 - The y component of the normal of the plane.
 - normal z
 - The z component of the normal of the plane.
 - base x
 - The x component of the base point of the plane.
 - base y
 - The y component of the base point of the plane.
 - base z
 - The z component of the base point of the plane.
Examples
*createplane 1 1.0 0.0 0.0 2.0 3.0 4.0
