*absorbbeamsections
FE-absorb 1D properties into beam sections.
*absorbbeamsections ?<select_type>=<selection>? ?option=<value>? ?tolerance=<value>? ?deleteunused=<value>?
HyperMesh Tcl Modify Command
This command creates/compares beam sections with 1D property values as per the options provided. Currently valid only for OptiStruct and Nastran profiles.
- <select_type>=<selection>
 - The properties to be modified. There are several ways to provide the entities to be
            modified. Only one option can be used at a time.  If not specified, all properties in
            the model are considered:
- id=<id>
 - The ID of the single entity to modify.
 - mark=<mark_id>
 - The ID of the mark containing the entities to modify.
 - deleteunused=<value>
 - 0 - Preserves the beam sections not referenced in any entity.
 - option=<value>
 - 0 - Create new beam sections if there are not beam sections attached to the 1D properties (default).
 - tolerance=<value>
 - Valid for option=1 to compare the beam section values and property values with the user defined tolerance value. Default value is 0.01.
Examples
*absorbbeamsections*absorbbeamsections option=0*createmark props 1 all
*absorbbeamsections mark=1*createmark props 1 all
*absorbbeamsections mark=1 option=0*absorbbeamsections id=1 option=1*absorbbeamsections id=1 tolerance=0.05*absorbbeamsections id=1 option=2Errors
   # Handle error
}Version History
2019
