*attributeupdateintarray2d
Updates an attribute of type 2D int array.
*attributeupdateintarray2d entity type id identifier solver status behavior data rows cols
HyperMesh Tcl Modify Command
- entity type
 - The type of entity that owns the attribute.
 - id
 - The ID of the entity
 - identifier
 - The identifier of the attribute.
 - solver
 - The solver number of the attribute.
 - status
 - The status of the attribute.
 - behavior
 - The behavior of the attribute.
 - data
 - The 2D array of ints.
 - rows
 - The number of rows in the array.
 - cols
 - The number of columns in the array.
Examples
Update an attribute of type 2D int array to [1,2,3] on the material with ID 7.
*createintarray2d(2,3) 1,2,3,5,6,7
*attributeupdateintarray2d(materials,7,615,2,2,0,1,1)
