*markprojectnormallytosurface
Project nodes, elems, points, or lines onto the surface along the surface normal.
*markprojectnormallytosurface entities markmask surfptr
HyperMesh Tcl Modify Command
- entities
 - The type of entity being projected.
 - markmask
 - The mark which contains the entities to project.
 - surfptr
 - The ID of the surface to which the entities will be projected
To project nodes 22, 23, 24, and 25 to the surface along the normal to the surface 14:
*createmark(nodes,1) 22 23 24 25
*markprojectnormallytosurface(nodes,1,14)
None.
