*CE_FE_AutoRegisterSharedEntitiesByMark
Auto register pre-existing entities to multiple connectors.
*CE_FE_AutoRegisterSharedEntitiesByMark mark_id
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark containing the connectors to register to. Valid values are 1 and 2.
Register to connectors 1-10:
*createmark connectors 1 1-10
*CE_FE_AutoRegisterSharedEntitiesByMark 1
   # Handle error
}Version History
2017.1
