*morphconstraintcreatelength
Creates a model type constraint based on the length of a list of nodes.
*morphconstraintcreatelength stype smark type name nodes vec length bound color
HyperMesh Tcl Modify Command
- stype
 - SHAPES
 - smark
 - Mark number of shapes
 - type
 - 0 - Measure length node to node
 - name
 - Name of morph constraint
 - nodes
 - Mark number of node list
 - vec
 - The ID of the vector created using *createvector. Must be set to 1.
 - length
 - Constrained length of node list
 - bound
 - -1 - Greater than specified length
 - color
 - The color of the constraint. Valid values are 1 through 64.
*morphconstraintcreatelength (SHAPES,1,0,"length",1,1,43.5,0,32)
      This command creates a model type constraint for the selected node list with the option of having those nodes measured node to node or along a vector and the option of having the node list forced to be greater than, less than, or equal to the specified length.
The shapes on the mark will be used to force the model into compliance with the specified constraint, if possible.
None.
