*convertunit
Converts entity values from one unit system to another unit system.
*convertunit source_unit_system=<value> target_unit_system=<value> ?entity_type=<entity_type>? ?mark=<mark_id>?
HyperMesh Tcl Modify Command
Converts entity values from the source unit system to the target unit system. If entity_type and mark are specified, only the entities specified on the mark are converted. If only entity_type is specified, all entities of the specified type are converted. If neither are specified, the whole model is converted.
- N_m_s_kg
 - kN_mm_ms_kg
 - N_mm_ms_g
 - N_mm_s_T
- entity_type
 - The type of entity to convert.
 - mark=<mark_id>
 - The ID of the mark containing the entities to convert.
 - source_unit_system=<value>
 - The source unit system.
 - target_unit_system=<value>
 - The target unit system.
Examples
*createmark mats 1 1 2 3
*convertunit mats mark=1 source_unit_system=N_m_s_kg target_unit_system=kN_mm_ms_kg *convertunit mats source_unit_system=N_m_s_kg target_unit_system=kN_mm_ms_kg*convertunit source_unit_system=N_m_s_kg target_unit_system=kN_mm_ms_kgErrors
   # Handle error
}Version History
2021.2
