*CE_FE_UnregisterSharedEntitiesByMark
Un-register registered entities from multiple connectors.
*CE_FE_UnregisterSharedEntitiesByMark mark_id
HyperMesh Tcl Modify Command
This will only remove the references of the entities from the connectors. This will not delete the actual entities. This sets the connectors to the modified state after the un-registration.
mark_id
The ID of the mark containing the connectors to register to. Valid values are 1 and 2.
Un-register from connectors 1-10:
*createmark connectors 1 1-10
*CE_FE_UnregisterSharedEntitiesByMark 1
   # Handle error
Version History
2017.1
