*alignnode3
Aligns multiple nodes along the imaginary line between two other nodes.
*alignnode3 end_node1 end_node2 mark_id
HyperMesh Tcl Modify Command
end_node1
The ID of the first end node.
end_node2
The ID of the second end node.
mark_id
The ID of the mark of nodes to align. Valid values are 1 and 2.
Examples
To align nodes 100-110 between nodes 200 and 300:
*createmark nodes 1 100-110
*alignnode2 200 300 1
   # Handle error
Version History
14.0
