*setsimulationstep
Sets the current subcase and simulation step.
*setsimulationstep subcase_id simulation_id
HyperMesh Tcl Modify Command
Sets the current subcase and simulation step. All the result plots retrieve their values based on the current subcase and simulation step.
- subcase_id
 - The HyperMesh result subcase ID.
 - simulation_id
 - The HyperMesh result simulation ID. The referenced result simulation should belong to the referenced result subcase.
To set simulation step 1 of subcase 2 as current:
*setsimulationstep 2 1
   # Handle error
}Version History
2021.2
