*add_multi_washer_elements
Adds washer elements to circular holes of shell meshes.
*add_multi_washer_elements node_mark_id feature_angle string_array number_of_strings periphery_node_mark_id background_elem_mark_id rigid_spider local_cordinate_system
HyperMesh Tcl Modify Command
This command is used to add washer elements to circular holes of shell meshes. Multiple holes can be handled at a time.
- node_mark_id
 - The mark of nodes on the circular holes to add washers to. Valid values are 1 and 2.
 - feature_angle
 - Defines the mesh feature lines around washer elements. The range should be (0, 180). It is usually set to 30.
 - string_array
 - The string array ID that contains the washer element information. The string array is created using the *createstringarray command. This should always be set to 1.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray.
 - periphery_node_mark_id
 - The output mark of periphery nodes generated on the hole. Valid values are 0, 1 and 2.
 - background_elem_mark_id
 - The output mark of background elements to be deleted in order to update the connectivity of the newly created elements and their neighbors. Valid values are 0, 1 and 2.
 - rigid_spider
 - Valid values are 0, 1 and 2. If the value is set to 0, no rigid elements will be created inside the hole.
 - local_cordinate_system
 - 1 - A local coordinate system will be created in the plane of the hole.
Examples
To add washer elements around the hole containing node 60, using 2 element layers of uniform size, a density of 8 and a width of 5.0:
*createmark nodes 1 60
*createstringarray 2 "layer_number = 2 uniform_layers = 1 hole_density = 8"  "1 5.0"
*add_multi_washer_elements 1 30 1 2 0 0 1 1
   # Handle error
}Version History
13.0
