*nodemarkbypath
Creates a node path from the starting node to the ending node.
*nodemarkbypath node_id1 node_id2 mark_id
HyperMesh Tcl Modify Command
Creates a node path from the starting node to the ending node. If both node_id1 and node_id2 lie on free edges, the path will follow free edges where possible. Otherwise, the shortest path is returned.
- node_id1
 - The ID of the first node.
 - node_id2
 - The ID of the second node.
 - mark_id
 - The ID of the node mark to populate. Valid values are 1 and 2.
To determine the path between nodes 100 and 110:
*nodemarkbypath 100 110 1
   # Handle error
