*adaptive_wrapper_preview
Previews the cavities for the adaptive wrap mesher.
*adaptive_wrapper_preview ?num_cavities?
HyperMesh Tcl Modify Command
In case of a cavity mesh, this command can be used to preview cavities which are detected by the adaptive wrap mesher. For each cavity, a unique component is created which holds the shell elements defining the cavity.
This command must be called after *adaptive_wapper_build.
num_cavities (optional)
The number of largest cavities to display.
If 0 or not defined, then display all cavities.
Examples
#Initialization of wrapper mesh with base mesh
*createmark elements 1 "all"
*adaptive_wrapper_init elements 1 1 0
#Build skeletal octree structure
*adaptive_wrapper_build
#Preview all cavities
#Clear the preview
*adaptive_wrapper_preview_clear
#Generate Mesh
*createstringarray 2  "DoRemesh: 1" "RemeshGrowthRate: 1.2"
*adaptive_wrapper_mesh 0  1 2
#End of wrapper mesh
*adaptive_wrapper_end
   # Handle error
Version History
13.0
