*surfacecopyedges
Create lines from the edges of a surface.
*surfacecopyedges surface list all_edges
HyperMesh Tcl Modify Command
- surface
 - A surface that contains edges (a full sphere or torus does not contain edges).
 - list
 - The mark ID of the nodes used to select the surface edges (if all_edges is 0).
 - all_edges
 - 1 - Copy all edges of the surface to new lines.
To copy all edges of surface 1 to new lines:
*createlist(nodes,2)
*surfacecopyedges(1,2,1)
      *createmark() is required for this command.
None.
