*meshline_create_from_points
Creates meshlines from a node list.
*meshline_create_from_points list_id reserved1 reserved2 reserved3 reserved4 reserved5 reserved6
HyperMesh Tcl Modify Command
This command creates meshlines from a node list.
- list_id
 - The ID of the list containing the nodes. Valid values are 1 and 2.
 - reserved1
 - Reserved for future use. Must be set to 0.
 - reserved2
 - reserved3
 - reserved4
 - reserved5
 - reserved6
To create meshlines from nodes 470, 480, 475 and 485:
*createlist nodes 1 470 480 475 485
*meshline_create_from_points 1 0 0 0 0 0 0
   # Handle error
}Version History
11.0
