*readqiviewsettings
Loads a file containing the element quality view mode settings.
*readqiviewsettings file
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It loads settings from a text file created by *writeqiviewsettings, and resets the current settings used in this view mode.
flag
The full name and path of the file to load containing the QI view settings.
To load the current settings from the file C:/settings/qiview.txt:
*readqiviewsettings "C:/settings/qiview.txt"
   # Handle error
Version History
12.0.110
